ETH-ETC injectors
Gauge recommendations for towing?
Fuel Supply Problem
Yes. Dyno testing indicates a gain of 33 hp with the 5 speed engine, 42 hp with ETH, and 50 hp with automatic trans equipped engine. If that isn't enough, you might check out Diesel Dynamics. I have a set of their [censored] injectors in Sickly.
Joe I think you have the conversion kit that allows you to actualy plumb the injector lines right into the cylinder. Removing that restriction otherwise known as an Injector ;)
Well... ... ... ... . there is no comparison. These DD2s smoke less and give better mileage. My clutch is even holding out fine. no slippage yet. Well worth the money and I bought them from Piers if that was your next question :)
<<Joe I think you have the conversion kit that allows you to actualy plumb the injector lines right into the cylinder. Removing that restriction otherwise known as an Injector >>
And, for those who are faint of heart, and conservative [or under warranty :p ], you can just hold the tip of each injector to a bench grinder until you can see a hole ground in the end :rolleyes:
:D :D
<Joe I think you have the conversion kit that allows you to actualy plumb the injector lines right into the cylinder. Removing that restriction otherwise known as an Injector>
And, for those who are faint of heart, and conservative :p , you can just hold the tip of each injector to a bench grinder until you can see a hole ground in the end :rolleyes:
:D :D
