the 6. 7 is junk no good
do you have one ?? have you driven one ??? or are you just spouting off at the mouth about something you know nothing about ???? i like mine .
I think for the people who use their trucks on longhaul, like EB above, they will do great, at least for the first 300K or so.
For those who use them as grocery getters, I think they will have lots of problems, and it's probably better now to buy a hemi, and keep the money, and spare yourself the trouble of the 6. 7.
It would be nice if it could be explained how the pickup knows that 7% fuel is in the crank case. I chanded my oil last time when the light came on an had just a trace of fuel in oil(according to Blackstone). I understand that there are more parameters than this but it is not taking samples its self. I am still going for extended intervals with testing. Edit. I remember there being a post on here about 4% being the acceptable level. Someone please let me know is acceptable or not. I guess 7% is it if that is what starscan tech said.
From the posts here it seems that there may be a relationship with how the truck is driven and fuel dilution. Since Courierdog reports little fuel dilution but high engine utilization I theorize the dilution is caused in part by the DPF regen process. An engine that is under high load (high EGT) should expect fewer regen cycles since the EGT's keep the soot build up in the DPF down.
As I understand it, the regen involves extra fuel being injected during the exhaust stroke to provide the extra heat the DPF needs to regen. Some fuel is certain to escape by the rings under any circumstance. However, during normal combustion it should be very small since the fuel is burning at the combution event. In this case, during regen, raw fuel is being injected into the engine during a non-combution event. Surely a greater amount of fuel will bypass the rings under this circumstance.
As far as ill effects caused by fuel dilution, I'm sure no good can come of it. The only question is how serious is the issue. I suspect that the oil change light is a method to help insure that fuel dilution does not exceed an excessive level. How well it succeeds in that measure is a question.
Since high utilization engines seem to require less frequent oil changes my guess is that the oil change alert light is a reasonable predictor of when oil dilution has reached unsatisfactory level.
All of this makes me more convinced that removal of the DPF (while retaining the sensor) will enhance economy and the reliability of the engine. I also think a mild power enhancement box that advances fuel timing will help as well.
Our area does not utilize emissions testing for diesels and are not expected to do so for the foreseeable future so inspections are not an issue for me. Warrantee is an issue, so I will wait a bit for these enhancements to see how things shake out.
jimnance, you make some very good observations, but;
1. The ECM will have no idea you removed it, so that would have no effect on the fuel being injected on the exhaust stroke, thus no change in dilution.
2. The oil change reminder light is there for a specific purpose. To remind the driver the oil change is needed based on THE TRUCKS duty cycle. Failure to heed the warning could result in engine damage.
3. Fuel dilution in the oil is not a problem if it does not exceed the limits set in the program. Again, you can choose to ignore it, but you’re just risking potential damage. I would not worry at all if you follow the manufacturer’s recommendations.
4. The reality is here that emissions have to be reduced, and Cummins and Dodge are not going to risk $10,000 short block replacements if they thought driving them normally and following the maintenance recommendations would compromise the engine life. This isn't a 12 valve anymore, and we have to change with the times. I don't recall that there is a law that because it used to be the way it was, means it has to be that way forever.
Trust that corporate America would rather do things the way they want, and not the way some law or regulation said they had to. You can also bet that the costs of all that emission equipment was not recouped by the minimal price increase of the 6. 7. In the end you still have to remain competitive.
1. When you remove the DPF and CAT, and disconnect the sensors the ECM knows something is wrong and does not regen. BUT it will derate the engine after about 50-100 miles. I know this from experience.jimnance, you make some very good observations, but;
3. Fuel dilution in the oil is not a problem if it does not exceed the limits set in the program. Again, you can choose to ignore it, but you're just risking potential damage. I would not worry at all if you follow the manufacturer's recommendations.
2. My experience with most of the folks that buy these trucks, is that they don't need to be reminded to change their oil. Dishing out almost $60k for a new vehicle is reminder enough for me to keep an eye on it and protect my investment. I am much more inclined to think it is their way of covering there ***** for a leaky injector issue. I can hardly believe that they are not checking injectors to confirm that this isn't the problem, Just automaticly assume it is from the REGEN events.
3. If as you say, fuel dilution in the oil is not a problem if I follow the manuf recommendations, than which recommendation should I follow. They say it is recommended at 7500 miles but then they have the computer tell you 3000 miles. And if it is not problem,,, then why did GM double their manufacturer warranty on the engine when they had this issue with leaky injectors back in 02 and 03. Are there engineers not as smart as Dodges. Sorry but I don't believe it.
you said it best, diesellady,
thats why my 6. 7 doesnt regen, it doesnt have a dpf nor the 2 cats any more. now i am wondering if the fuel in the engine will stop. a few days after each oil change you can see the oil rising.
The 6. 7 injector is essentially the same as a 5. 9, so why would they be leaking all of a sudden?
And from what I can tell, the 2010 diesel emissions standards were set to control particulates (DPF), Sulfur (ULSD), and NOx (EGR), not to increase fuel economy. The industry HAS to meet those standards before they can even start to address the other issues.
