Exchanging gauges?
4" exhaust - straight vs. muffled
Has anyone ever taken Ziebart to small claims?
I have a pillar, and dashtop setup.
The dashpod has black gauges, and the dual pillar has a white westach fuel pressure gauge, and an hour meter(I'm losing that)
I am going to pput a steering column pod on for my FP gauge. I want a black FP gauge for this, to match my stock and other gauges.
If I buy a gauge, can I just use the wiring from the westach on the new gauge, or will I need to use the new gauges stuff?
Here's a pic to show you my current setup,
The lighting wiring on your Westach can be swapped to almost any guage. The sending unit would have to match the new gauge. If you go with a compatible westach, then no problem. Otherwise, you would need to get a new sending unit, which isn't too difficult. If you go mechanical, then all you keep is the gauge lighting wiring.
I sent you a p. m.
-Jason
