I'll try to keep this short and sweet - The other day while rowing through the gears pulling onto the interstate (engine and transmission were at operating temps as I was on mile 150 of my trip) I kinda missed a gear and heard a quick grind. That in and of itself is no problem, but now I hear a whine/whistle that seems to be turbp related. When I was accelerating I hit about 3k rpm. The whine sounds gear or bearing related but it is certainly turbo related as I can make it go in and out with boost. This could be normal and I am just now noticing it as my hearing is not good at all and in the last month has been in and out with congestion and is exacerbated with changes in elevation. (Like driving through SW Wyoming/ NE Utah. )
Anyway, today whilw driving down I-80 a short distance and through work areas I noticed a big ol' puff of white smoke whenever the exhaust brake clicked off. Whether I hit the button on andoff or I used the pedal, the result was the same. At first I thought it was cement dust from the road I saw in my mirror but I was able to reproduce it at will. It ONLY happens with the e-brake being switched on and off.
Any ideas as to what in the heck is going on? I have had really wacky readings from the boost gauge recently (from 0-60 with the e brake on) so I checked the coolant level just in case the boost gauge wasn't lying and I might be dealing with a blown head gasket, but the level is fine and there is no mess under the hood. I also did notice that my oil level is low. I'm desperate to try and find a culprit or problem before major damage is done to something again. Please help if you can!
