AH64ID
Should be a great setup.
You will need to find what psi the banks operates at and regulate down to that pressure. Since the Banks doesn't use a tank it's probably a lower psi than the Kilby will keep the tank at.
I was just looking over the Banks manual and noticed the brake is remote mount, and doesn't work with cruise... that sucks! But re-wiring the setup should allow you to use the brake in conjunction with cruise. I would pull every piece of Banks wiring off and wire it just like the Jacobs, but instead of a vac solenoid it will be a pressure solenoid.
