Hi Guys,
Just added a set of 305 Maxxis Big Horn meats on the old girl the other day and the front tires rubs the rear plastic fender liner "just a bit" when turning. It will only rub when the nose of the truck is taking a dive, or backing up, etc.
My control arms, bushings have 370K on them so I'm considering replacing them, they have got to be shot! The free-spin hub kit I installed on the truck moved the WMS out by an inch or so, I believe that is making the tire clearence a bit tighter. The truck has 2006 Dodge Power Wagon aluminum wheels and the positive back spacing is VERY deep.
I have read that buying custom control arms that are 1/2" longer than stock will cure minor clearence problems. Makes sense, the slight rub is in the back of the fender wells. . on the plastic well liner. The truck has no lift and there is plenty of room in front of the tires.
Anyone else gone this route? Appears to be several companies building the arms with an extra 1/2"... so it must be fairly common mod?
Thanks for your feed back.
