I have recently started having a problem with my 2000 QC , When I start it it , it takes several revolutions before it fires up . This does not happen every time , it happens when hot or cold . This appears to have started after a lift pump replacement . I have a pressure gauge which reads 14psi idle and 10psi wot . It doesn't seem to make a diff. whether I let it build pressure or not and I have not got a check engine light on . The gauge is a electric dipricol and the schrader valve is removed at the filter fitting, gauge was installed after lift pump died , has anybody run into this problem before?
________________________________________________________
2000 QC 4x4 3. 54 auto
