I recently purchased an EZ from Con for my Y2k and what a difference in power. He gave me a unbelivable price for a new unit with the boost elbo. So far the trans is stock with the pressure turned up per DTT instructions. I will upgrade the trans later with a new TC and VB when more funds become available. But after putting the EZ on it seems to shift better than it did. I don't know how long it will last but it sure is fun. From other posts I have read the EGT should be lower that stock with the EZ installed. I am not using the boost elbo because I don't have the guages yet. I don't know if the MPG is better but I'll see next fillup.
Can someone comment on a good set of guages that are not to expensive.
Also Can someone comment on if a boost elbo will raise or lower the EGT's and will it cause me to blow a head gasket?
I usually don't drive it very hard but it is nice to know ithe power is there when you need it.
