EZ plus DD1- good combo??
U-Joints --- Greaseable or Solid?
Boost readings
Looking for a combination to put on my ETH for good low end grunt, good fuel mileage, and driveability (can use cruise control).
Not looking to build a racer, but a good heavy hauler.
Have read previous posts about VA boxes W/DD1
that sound good, but was wondering how the
EZ/DD1 combo works.
Deezul Doug-2001. 5 ETH/DEE,QC 4x4,3. 54 anti,
Tow/Camper,Westin SS Step Bars,relocated breather.
Tow #1 - 6x12 Interstate inclosed cargo trailer.
GVW 7500
Tow #2 - Starcraft camper trailer
GVW 4500
2001 Volvo S80T twin turbo
You might want to consider the DD TTPM. It is made by EZ to DD specs. The box does timing, fuel, and boost.
1999 2500 4x4, auto, 3. 54 LSD, HD241, Quad cab SLT, Blk Sport Pkg, 16x8 Eagles, 285 Bridgestone AT, 100% Amsoil, 80/100w lights, Valentine One, DTT TC/vb, Mag-Hytek trans pan, DD2's, DD TTPM, Isspro gauges.
1992 SC400
1978 Mooney 201 IFR
Doesn't the EZ do timing, fuel and boost also?
GVW 7500
GVW 4500
I have that combo and it works great.
2001 2500 QC, ETH/DEE,4:10s, LSD, EZ with elbow(26. 5PSI)Stage 1 injectors from Carl, Boost/Pyro Guages, 4" Turbo back, BD Brake,Mag-Hytec Cover, Kleen Wheels, Energy Release, 70 gal. fuel, 20K Reese. 31,000 Miles on 03/01/01(Auto/Truck/RV Dealer)
Doug, that will be a great combo. Go for it. Might endanger your clutch if you push it hard though.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Everything but leather NRA Member Great Lakes TDR Member
I have the EZ-DD1 combo. I replaced the banks ottomind with the EZ. More power, better mileage, smoother idle and power, and now my cruise control works good. At 55-60 mph the cruise surges just noticably, but over that it is perfect.
1998. 5 QC 2500 4X4 24 VALVE, INTENSE BLUE, 235-85 MICHELIN, BANKS STINGER,DD Stage1 injectors, BD ebrake, PE-EZ to replace the Banks ottomind box ,5 Sp, 3. 54
Doug, why not try either the DD or EZ box alone first. I had the EZ on my ETH with stock injectors and was real happy with the performance. I think your going to be looking at a clutch replacement sooner rather than later, especially since you tow, if you add injectors. You will be suprised at what the EZ alone will add.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Go-Rhino grill guard,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
Doug, yes the EZ does the same thing as the DD module. The DD version is slightly detuned to work better with their injectors(less smoke).
You can drive with the EZ and DD1's and not get smoke, if you're light on the pedal until boost is up.
I run the EZ with the DD2's and I get little blake puffs when taking off. Not bad enough to worry about.
Plus with the fueling adjustments, you can set it lower, so the fueling comes in later. The timing is set, so the adjustment is for fueling. Not how much but when it kicks in.
Fred Swanson
Co-Owner
Canyon State Components, LLC
www.canyonstatecomponents.com
'00 QC,SB,4x4,Auto,3. 54 w/LSD,Trailer Package,Tow Package,DTT's
VB,DD2's,EZ,HOT PE
[This message has been edited by cscpusher (edited 03-30-2001). ]
Thanks for the info, guys.
I've got an EZ coming from Barry (great price!) #ad
so guess I'll start off with just the box- AFTER I get the gauges in!
Sure would like the better flow DD1's- but NOT if it's going to fry the clutch!
Just read the latest TDR Mag with the clutch article in it--what a liteweight piece of trash DC mickey moused in to fit #ad
The DD true torque module is not a detuned Edge. The difference is in timing primarily. Lawrence did extensive dyno testing and prefers different timing specs from what Edge uses.
I think the DD is detuned or else why the different HP # DD-50HP, EZ-65HP, DD-100 torque, EZ-165 torque, and yes the timeing is different. Regards, Ron
1999, 3500, 6x6, slt, auto, 3. 54, Qd cab, ISB cummins, towing 2001 26RKSS Tahoe 5th wheel, 1999 120hp 1800 bayliner.
