It was no big deal. the ford and dodge driveshaft are the same exact size. I washed the weld out on the dodge. We cut the ford shaft to length and squared it off to make sure the cut was straight. then inserted the dodge yoke into the ford driveshaft and welded it up. some of my friends are great fabricators. the transmission mount is the top half of the dodge transmission mount with the bottom cut off. then welded to the ford isolation mount. You push the crossmember back until it lines up and drill some new holes. the only tricky part is making sure the mount is the right heigth. with to two piece drive shaft you have to be careful with your alignment. as for the intercooler it fits great. you have to cut the small vertical support that runs in fron of you a/c condenser. fab a support out of flat bar, blow a couple of holes in it and set the intercooler in it with the stock iso mounts. if you want I'll get some pics. copterdoc
