Factory Power Sliding Rear Window
window up/down control doesn't work
16 inch chains fit 17 inch
I should be getting my new 07 6. 7L CTD on Sat. Is it possible to add the factory PSW? Is the wiring there? Can I get the p/w and the switch?
power sliding rear window
Hello, I see that this is an older post, but I was wondering if you got an answer... can a power sliding rear window be added if it didnt come from the factory?
Wondering the same thing for my 2005. Also wondering if people have had problems with the OEM power sliding window??
Thanks. Now does anyone know if an OEM power slider window can be retrofitted into a standard rear slider?? I would imagine so, with maybe the hardest part being the wiring, but has anybody done this on a 3rd gen??
