Trying to solve P0480 fan speed. Where is the connector and sensor located. I would like to clean the connectors. All was well until driving in some wet weather. Can this minor code set the check engine light?
Thanks for the input. In the next few days I will do some testing on the fan issue. Plan to compare if the air flow is increasing when the Temp. reaches the point to activate the clutch, 190 degrees or higher. Will provide an update after testing.
