Truck (purchased used) has some frayed wires on the drivers side of the radiator connecting to the fan clutch, however there appears to be a connector at this point as well where the splice was done.
Question is, does the fan clutch connect at the drivers side of the radiator then use a jumper to the connect to the main harness at the bottom of the radiator or is there just one connector that should run from the fan clutch to the harness. A look through the 2004 parts guide reveals no solid results.
