Except for the differences in temp and air density, you could probably control the others. If your amient conditions did not change with the seasons then you could eliminate more variables and get close.
Pretty sure the 20, 25, and 27 HP were developed on a dyno but thats again at the top of the rpm range and likely the fan 100% locked. How much at 2000 rpms on 70 degree day? Not sure it can be claculated with an efficacy.
Trying measure mileage difference in th winter fan on\off is hit or miss too because the ambient has so much to do with the efficiency. Likely, without the fan the engine gets warmer and more efficiency because it is not loosing as much heat thru the cooling system. Can't attribute that directly to the fan.
As far as SOP, I have not been able to tell the difference in power. Have not run it long enough in enough different conditions to tell if there is a benefit either. Others claim differently but without some solid facts and controlled test, its still just an opinion.
Up to you want you want to believe and figure is the best.![]()
i know around here i dont notice much between winter and summer mileage. thats me being the only driver, and no changes to the engine. i have noticed looking at my records that sept and oct seem to be my best months for fuel mileage. i think its because the ambient temps and conditions are the closest to prime in those months.
im asking people to get an idea. the more responses i get the more acurate the info. it helps elimenate the variables.
