HEMI®Dart
Did any of you guys have trouble with the nut on the clutch being VERY tight?
I'm holding pulley with an 18" Pipe wrench.
Have a K&D clutch nut wrench with a torque wrench as additional leverage.
I'm turning Right/Clockwise to loosen it. It should be a left handed thread.
Can't budge it. Tried giving the wrench a few hits with a rubber mallet to break it loose.
When I was pulling with everything I had, I heard the torque wrench click. I was curious to what I had the wrench set at..... 120 ft lbs!
Dodge dealer replaced the clutch in 1996.
Service manual says torque should be 42 ft. lbs.
Any suggestions?
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7 º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno`s Exhaust Blanket,Espar Heater (won it!), Synthetic lubes throughout.
[This message has been edited by HEMI®Dart (edited 12-29-2000). ]
Any suggestions?
Bill R
