Following up on this:
Have run the Fass for about 3 months now, and have a couple observations (on my truck only - your results may vary).
1. Truck is more consistant. Smoother all around, and always strong & very "torquey" at any RPM, in any situation. It used to be more "moody", as some days it would even sound different than others. Now its consistant. This thing pulls.
2. Pressure is very stable, even when purposely running the fuel level in the tank low, retained the OEM filter/heater inline (fuel line upgrade from that to the VP), can only pull it down 1. 5 psi. (DD3's+VA / about 350HP).
3. It still smokes, dont think there has been a reduction.
4. MPG's are about the same.
5. The quieter motor is probably due to not having the OEM pump running up under the hood anymore, as that is where it sounds quieter from.
6. My VP44 doesnt like higher pressure, and is hard to start warm when pressure is 15 or higher. Have tried settings from 10 - 22 psi, and found it is happiest at 12-13. Always fires quick again. No more hard starts.
7. The Fass fuel filter weeps fuel. Havent been able to stop it yet. Its not bad, and doesnt drip, but its close to it.
8. Anytime after making a change, it takes about a week to get all the air purged from the system. Might have a hard start or 2 for a few days. Then goes away. .
9. If you plan to adjust your pressure spring, make sure your tank is less than about 1/2 full, or when you remove the return fitting, the fuel level is higher than the fitting, so you have a constant siphon through the pump, from the tank, and a diesel fuel bath! Much easier when the fuel level is low - trust me.
10. It did fit on my 2000 short box 4x4, but is pretty tight in there. I did not enjoy the install.
Bottom line: Very Satisfied w/ the FASS. It did take some fiddling to get there, but now I feel this is "a" logical attempt to improve our fuel pump fiasco. Its about as good as its going to get. If the VP dies, it wont be due to fuel starvation.
One alternative I would have liked to try, would be to mount 2 (pumps of your choice) in a top/bottom configuration on the frame, and have the ability to quickly change pumps by moving the lines up or down to the other pump, and moving the wiring harness.
But this FASS is a beefy unit, and we all can appreciate that. So far it has operated flawlessly.
Hope this helped someone. over & out. '73s O. M.
