Mark,
Talked to your dealer this morn. Do me a fav and check the coolant/Gauge side of the isolator. Make sure you don’t have a big air pocket there as well. I really hate to beat this isolator to death…but like I said…I see a lot cause issue.
That squealing is the by-pass ball resonating... . which it would only do if you were at 18 PSI where the pump is set up to dead head at. While the squealing should not be happening, it’s not hurting anything. What most have told me is when the spring breaks in, it will stop. We do everything on our end to not let them go out like that and a simple spring and ball change is usually what is needed to fix the issue. I feel you are getting correct pressure on this pump.
The HPFP is a static flow pump. Meaning that it will not move huge volumes of fuel all the time like the FASS. It’s set up to only push what fuel is needed at the time of demand. SO you will not empty the bucket out that you were testing with. This is normal.
