Engine/Transmission (1998.5 - 2002) FASS on a '99
To the people with a FASS on a '98 or '99 ISB. If you are using the OEM filter housing, where did you get the fittings to connect the fuel filter housing to the FASS fuel hose?
TIA,
Dan
I'm not sure if I was clear or not. I have had this unit for a few years and haven't ever used the Dodge fuel filter/water seperator. I have been thinking about putting the OEM filter back into the system and don't see the fittings for it in my FASS box. I didn't see them in the manual either.
Dan
You can get what you are looking for from Vulcan PerformanceVulcan Performance Home Page I have an AirDog system, but the plumbing is going to be basically the same, I eliminated the banjo fitting and factory line from the filter housing to the VP44 and replaced with an 08 line from Vulcan.
