fass water seperator
Does Goerend return e-mails?
Anti Gel
I'm looking for any water seperators that fit the fass napa,wix,fleetguard, etc. I changed the fuel filter but still have low and eratic pressure. Thanks
jwilliams3 said:
FS1023 available @ www.fleetguardfilters.com you have to call and ask for it.
IIRC when I researched this, the FS1023 is the only filter that fits that mount, it has no other replacement...
Are you sure your guage is alright?? Are you getting air? I know I have read of guys having issues with the intank pickup...
steved
My local Southern Plains Cummins had the Fleetguard FS1023 in stock locally, but did not have the Fleetguard HF6604 3 micron filter in stock locally. If you have a local Cummins dealer they probably have one in stock.
The guage is hooked to injection pump. I always have 15 lbs at idle, but it drops down under throttle. Thanks
