I have the Mopar fender flares. The fit is excellent and they come painted to match your Ram. I was really impressed with the overall quality of the fit and finish. The down side... $$$.
If you are running 12. 50 wide 33" or 35" tires (16. 5s), the Warn 4x flares or the Bushwacker (non street version) provide the ultimate in protection.
Personally, I like the flares that have the 3M adhesive on the outer (i. e. , upper) periphery of the flare, effectively bonding the flare to the body. I have installed enough Bushwacker flares on previous 4X4s that I've owned (the only game in town back then) to know that the outer edge creeps along the paint during thermal changes, leaving behind scrape marks. Some have used a beading to reduce to some extent or eliminate this condition.
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & DD trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, Jordan Research Ultima 2020 trailer brake controller, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, "special" Brite-Box, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass w. trick billet block adapter and Aeroquip Teflon-s/s hoses, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP s/s fuel hoses, tricked out Cummins valve cover, tricked out Banks High-Ram and 14 cm2 (wastegated) turbine housing, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
COMING ATTRACTIONS: break out those sun glasses! Plus, BLACKOUT gets a "BIG GULP"
NRA Life (Patron) member
[This message has been edited by John (edited 05-15-2001). ]
