Just got the truck back tonight after a weeklong battle of getting a new injection pump. (See threads about "pusher pump too strong" and "pusher pump voids warranty". These are my observations and thoughts with the new pump:
1. Bouncing tach is gone. Sits @9100 rpms now and holds steady. Doesn't ramp up 100 rpms when I'm coasting to a stop either.
2. Dodge paper work says max. recommended fuel psi is 15psi. This is probably why the dealer was upset that my pusher pump ran 22psi. I think the 22 psi also explains why a code was set off that thought I was tampering with the truck. I figure the computer thinks I put a chip in there like the Edge COMP that boosts your pump up. Whatever it thinks, I got a new VP44 and my warranty is still good as long as I take my pusher off.
3. Do I think the pusher is causing issues? No, lots of guys here have had pushers for a while now and no VP44 issues. I think I'm a victim of a generation #1 motor and pump. I still value my 24k miles left of warranty so I think I'll take it off and store it. I'll watch my lift pump pressures closely though as it is still under warranty!
In the end, my dealer took care of me and I have my truck back. I'd recommend knowing a good dealer that is close to you that you know will take care of you.
I'll be interested to see if my fuel mileage goes up with the new pump, but I doubt it. Next step from here... put the EZ and the DDIIs back in!!!
