After a long battle I have finally gotten my tach to work today. I determined that my computer is screwed up in my truck for the tach output. I bought the isspro tach and hooked it up, and it didn't work below 1200RPM's. I posted a thread and ya'll said I needed the isspro harness. Well I bought it and hooked it up, and it didn't work at all. I sent everything back to isspro and they said the harness and tach were fine. I got them back and hooked it up sraight off the crank sensor, and it worked correctly up to 1500RPM's then would quit. My air gap was too big and it was loosing the signal, but my alt. , A/C, and cruise never had a problem, so who cares it finally read all the way up to 2500 at least. I didn't want to free rev it higher than that. I ended up unhooking the PCM plug and cutting the tach wire (43) and soldering it in with the crank sensor wire (24). Now my tach works off the under dash plug, and everything else seems to function correctly.
Note: If you want to run and Autometer tach in your truck, I'm pretty sure I have found a way. In my tach battle I bought a Dakota Digital SGI8 tach interface and got it to work staight off the crank sensor but it died at 1500RPM's like the isspro. I thought the SGI8 just couldn't read something in my truck so I sent it back. But I know now it was just the air gap that was too big. If you have a good tach signal it may work off that, if not just tie the wire in like I did along with the SGI8, and you should be in business to use any standard auto tach.
