inlet adapter
What do you do on the other end of the pump?? I have stainless steel AN6 lines from the pump to the VP44 with my lift pump on the frame. I have Webber carb adapters that screw into the lift pump so I can hook up the AN lines. It looks like the airtex pump only has the ability to have a hose slid on it?? But it looks like that end might be removable... . any help?
The inlet fitting is removable, it simply threads on with straight threads, not pipe threads and seals with an internal o-ring and thread sealant ( I used Permatex pn54540).
When I took the Airtex pump and the associated AN fittings to my machinist for adapters, he handled the inlet as follows; after removing it from the pump, he milled the inlet tube off while simultaneously milling a recess in the inlet end of the fitting. He then turned a brass cylinder, a coupler of sorts, of matching diameter, drilled, tapped and threaded one end, and silver soldered it to the brass fitting, inside the recess previously milled. The AN fitting then screws into the brass coupler. In the event that I ever have to replace the pump, which I doubt, especially since it is a Walbro Oo. , I'll simply remove the modified inlet fitting and transfer it to the new pump.
As a side note, for those that do not wish to modify the inlet fitting for a relocation kit, instead of installing the relocation kit supplied pushlock swivel connector on one end of the 3/8" fuel line supplied to go between the oe steel fuel line and the pump, just slide the 3/8" fuel line onto the fitting up to the collar and hose clamp it in place same as installing the other end to the steel fuel line cut to install relocation kit.
JR2, hope this helps and thanks for the support you voiced.
Feel free to send me a pm if you like and I will provide a phone number if you'd like additional help.
