First time post and question about air ride and quality of ride on 2019 3500.
New Member of the TDR Family
Finally made it around to Cummins
Yep thats what I was thinking, THEY MAKE A WHOLE BUNCH OF MONEY ON IDIOTS BLOWING UP THEIR 68rfe trannys and these guys give them BANDAIDS of sorts so they can blow them up again and again and get paid more money.
ATS sells a bulletproof 68RFE for over ten grand but you can order a truck with the Aisin for 3000 instead.
:D the Aisin is fine as long as the power stays stock, then it lasts even if misused - raise the HP level significant it will fail PRIOR to an 68RFE.
That's why the pullers and racers don't use it, there is only few support for modding the Aisin but quiet a lot for the Chrysler Trannys.
Edit: for a stock truck that isn't raced you simply don't need a built transmission, the 68 will serve you well.
And that it is only good for 100'000M is a just plain stupid idea. Sorry.
There are hundreds of thousands trucks out on the road with way higher counts on the tach then this.
Yep I understand I just made up this truck on Ramtrucks.com and I could purchase it for about 65,900 with discounts and the 410 rear end can only be had on a dually or so the dealer says so oh well for me I would love to have the 410.
My 14000 pound trailer that I am looking at getting should be no problem with the 68 and 373 gearing?????
2019 RAM 3500 LARAMIE MEGA CAB 4X4 6'4" BOX
6-Speed Automatic 68RFE Transmission
Vehicle images shown may not reflect the selected model year. See dealer for details.
MAX PAYLOAD
4260.00LBS
MAX TOWING
19790.0LBS
2019 RAM 3500 LARAMIE MEGA CAB® 4X4 6'4" BOX
Print Summary
Net price
$72,865
NET PRICE
ZIP CODE: 20001
Search New Inventory
Find A Dealer Near You
Get A Quote
Your ConfigurationAll Standard features
POWERTRAIN
Changepowertrain Configuration
Edit
6.7L I6 Cummins Turbo Diesel Engine
Sales code: ETL
6.7L I6 Cummins Turbo Diesel EnginePrice$9,100EditSelected$9,100
Sales code: ETL
OPENDETAILSDIALOG FOR 6.7L I6 CUMMINS TURBO DIESEL ENGINE
Edit
Sales code: DG7
6-Speed Automatic 68RFE TransmissionIncludedEditSelectedIncluded
Sales code: DG7
OPENDETAILSDIALOG FOR 6-SPEED AUTOMATIC 68RFE TRANSMISSION
Edit
3.73 Axle Ratio
Sales code: DME
3.73 Axle RatioStandardEditSelectedStandard
Sales code: DME
OPENDETAILSDIALOG FOR 3.73 AXLE RATIO
Edit
220-Amp Alternator
Sales code: BAJ
220-Amp AlternatorIncludedEditIncluded
Sales code: BAJ
OPENDETAILSDIALOG FOR 220-AMP ALTERNATOR
PACKAGES
Changepackages Configuration
Edit
5th Wheel / Gooseneck Towing Prep Group
Sales code: AHU
5th Wheel / Gooseneck Towing Prep GroupPrice$445Edit$445
Sales code: AHU
OPENDETAILSDIALOG FOR 5TH WHEEL / GOOSENECK TOWING PREP GROUP
Edit
Laramie Level 1 Equipment Group
Sales code: A66
Laramie Level 1 Equipment GroupPrice$1,600Edit$1,600
Sales code: A66
OPENDETAILSDIALOG FOR LARAMIE LEVEL 1 EQUIPMENT GROUP
Edit
Chrome Appearance Group
Sales code: AMP
Chrome Appearance GroupPrice$995Edit$995
Sales code: AMP
OPENDETAILSDIALOG FOR CHROME APPEARANCE GROUP
Edit
Bed Utility Group
Sales code: ANT
Bed Utility GroupPrice$695Edit$695
Sales code: ANT
OPENDETAILSDIALOG FOR BED UTILITY GROUP
Edit
Towing Technology Group
Sales code: AAN
Towing Technology GroupPrice$1,095Edit$1,095
Sales code: AAN
OPENDETAILSDIALOG FOR TOWING TECHNOLOGY GROUP
Edit
Safety Group
Sales code: AAU
Safety GroupPrice$795Edit$795
Sales code: AAU
OPENDETAILSDIALOG FOR SAFETY GROUP
EXTERIOR
Changeexterior Configuration
Edit
Diamond Black Crystal Pearl-Coat Exterior Paint
Sales code: PXJ_02
Diamond Black Crystal Pearl-Coat Exterior PaintPrice$100Edit$100
Sales code: PXJ_02
Edit
18-Inch x 8.0-Inch Polished Aluminum Wheels
Sales code: WBL
18-Inch x 8.0-Inch Polished Aluminum WheelsStandardEditSelectedStandard
Sales code: WBL
OPENDETAILSDIALOG FOR 18-INCH X 8.0-INCH POLISHED ALUMINUM WHEELS
Edit
LT275/70R18E BSW All-Season Tires
Sales code: TCN
LT275/70R18E BSW All-Season TiresStandardEditSelectedStandard
Sales code: TCN
OPENDETAILSDIALOG FOR LT275/70R18E BSW ALL-SEASON TIRES
Edit
LED Bed Lighting
Sales code: LPL
LED Bed LightingIncludedEditIncluded
Sales code: LPL
OPENDETAILSDIALOG FOR LED BED LIGHTING
Edit
Center High-Mount Stop Lamp w/Cargo View Camera
Sales code: LPD
Center High-Mount Stop Lamp w/Cargo View CameraIncludedEditIncluded
Sales code: LPD
OPENDETAILSDIALOG FOR CENTER HIGH-MOUNT STOP LAMP W/CARGO VIEW CAMERA
Edit
Chrome Flat Wheel-to-Wheel Side Steps
Sales code: MR5
Chrome Flat Wheel-to-Wheel Side StepsIncludedEditIncluded
Sales code: MR5
OPENDETAILSDIALOG FOR CHROME FLAT WHEEL-TO-WHEEL SIDE STEPS
Edit
Spray-In Bedliner
Sales code: XMF
Spray-In BedlinerIncludedEditIncluded
Sales code: XMF
OPENDETAILSDIALOG FOR SPRAY-IN BEDLINER
Edit
Monotone Paint
Sales code: APA
Monotone PaintStandardEditStandard
Sales code: APA
OPENDETAILSDIALOG FOR MONOTONE PAINT
INTERIOR
Changeinterior Configuration
Edit
Leather-Trimmed 40 / 20 / 40 Bench Seat
Sales code: VL
Black Interior Color
Sales code: X9_01
Leather-Trimmed 40 / 20 / 40 Bench SeatStandardEditSelectedStandard
Sales code: VL
Sales code: X9_01
OPENDETAILSDIALOG FOR LEATHER-TRIMMED 40 / 20 / 40 BENCH SEAT
Edit
Uconnect® 4 with 8.4-Inch Display
Sales code: UAM
Uconnect® 4 with 8.4-Inch DisplayStandardEditSelectedStandard
Sales code: UAM
OPENDETAILSDIALOG FOR UCONNECT® 4 WITH 8.4-INCH DISPLAY
Edit
Single-Disc Remote CD Player
Sales code: RH1
Single-Disc Remote CD PlayerIncludedEditIncluded
Sales code: RH1
OPENDETAILSDIALOG FOR SINGLE-DISC REMOTE CD PLAYER
Edit
Power Sunroof
Sales code: GWA
Power SunroofPrice$1,095Edit$1,095
Sales code: GWA
OPENDETAILSDIALOG FOR POWER SUNROOF
Edit
Front and Rear Rubber Floor Mats
Sales code: CLF
Front and Rear Rubber Floor MatsPrice$150Edit$150
Sales code: CLF
OPENDETAILSDIALOG FOR FRONT AND REAR RUBBER FLOOR MATS
Edit
Blind-Spot and Cross-Path Detection (Truck only)
Sales code: XAN
Blind-Spot and Cross-Path Detection (Truck only)IncludedEditIncluded
Sales code: XAN
OPENDETAILSDIALOG FOR BLIND-SPOT AND CROSS-PATH DETECTION (TRUCK ONLY)
TOTAL OF ADDED OPTIONS$16,070
I have all the safety goodies on the truck but the wire for the trailer camera ups the price by almost two grand.
What is this
Trailer Camera Wiring (No Camera)
$395
With Trailer Camera Wiring, you can install an aftermarket camera to keep an eye on whatever you're towing.
Would that go on the back of the fifth wheel I guess???????
Sounds good, but do you really want/need the front bench seat?
The otherwise standard center console is a magic of its own, many many compartments and doors and connectors inside, and the space of a porsches trunk. :cool:
It just burns me up lol the wife wants the Limited for 78,300 but I can get the one above for about 65,900 sure the less priced one has the rfe and not so many bells but man over twelve grand WOW thats a load of Diesel I can buy lol.
I think you should buy my dream truck. Tradesman trim, 3500 SRW/SO engine, 4x4, 5.0 radio with Bluetooth and back up camera, rubber floor, HD vinyl seats. Take the extra 20+k you'll save and take your wife on one hell of a vacation.
Thank me later for the "benefits package" that follows :D
Stuart,
I have been pulling two different 5er's since I bought my truck for pulling a 5er across country. It is a 2008, 2500 Mega Cab, 6.7L Cummins, 68RFE Auto 4X4, with 3:73 differentials. I purchased my truck in Nov 2007 and have been puling a 5er since. I now have 126,300+ miles on the truck and the transmission has not been touched, except for servicing and a deep dish MAG-HYTEC transmission oil pan. My transmission normally sees 180F when I am towing and be 200F when I am in the mountains such as on I70 when I went to Utah in 2017. I do have gauges on my truck for Boost, EGT's and transmission temps.
I am towing a 2016,34RL Cedar Creek since the summer of 2015. I have scaled my truck and trailer combination on a Cat scale and I am heavy, 20,500 LBS total weight,with a rear axle load of 6,050 LBS when towing. I have changed out my stock tires and rims for summer towing tires. These are Nitto Dura Grappler Tire which is a LT285/70R/17 126S rated tire. This means the tire and my MICKEY THOMPSON Rims will support a load of 3415 LBS each at 70PSI.
So, what I am saying is a 3500 SRW truck with a 6.7L Cummins, 68RFE auto and the 3:73 differentials with 18" tires will pull your 14,000 LBS trailer with no problem.
What is this
$395
The best I can tell, you can connect a wired camera from the trailer. I give my caveats this is my guess, not fact.
Cheers, Ron
yes the jayco that I am looking at has a in the back of the fifth wheel it has a mount for a camera it says it's already wired for a camera so I'm assuming and I'm not sure maybe you guys know better than I do maybe it's wired through the 7 pin connector that goes to the truck and that when you put it in reverse you put it in reverse it will show that rear camera on the back of the fifth wheel I'm assuming so but by getting that little option raises the price of your truck by about 1999 or 2000 dollars I don't know how I like to go with the Laramie one group and then if you want to get an IOU no more price on your truck and go for the latter me too but I like going for the Laramie one group what are my guys if you know the only thing I can figure it out is that these except for the jayco 377rlbh it is wired in the back for a camera but I thought you didn't have to use a wire I thought it was wireless most of the time????????
the real complaint shame and all this is that you can't get a 410 rear end with anything but a dually and that just stinks I just wish it would be so much better for the 68rfe transmission to have that 410 rear end and we put a lot less pressure on all those components in the transmission from what I understand of physics but I don't know if any of you guys know anything about that but the dealership said they told me that you can order a 410 without a dually ever???????
I have a Furrion wireless OBSERVATION camera I wired into and mounted the camera above the center rear clearance lamp on my RV. Works fine and I can see everything good on bicycles and tailgaters. Don't get the backup camera unless the only time you want to use it is backing up. Lower bandwidth and price will lose picture when driving. monitor plugs in my cigarette, ugh, 12v plug and sets center on dash.
BL, I'd go for the aftermarket wireless one, but if mama wants it, who's to argue... mama's always right. ;):p:D
Cheers, Ron
