Engine/Transmission (1998.5 - 2002) Fitting for Trans Temp Gauge???
2nd Gen Non-Engine/Transmission Difficulty in changing clutches??
Engine/Transmission (1994 - 1998) injectors
My Trans pan doesn't have a drain plug for a trans temp gauge, but when I looked under my truck (driver side) about 3" to 4" above the pan center in the trans between the linkage close to the spring is a threaded plug with a 3/8 plug? in it. Can I use this or not or is it to close to the spring or does it have to be in the pan????
THANKS
2001 2500HD Quad Cab SLT LWB, Auto, 4x4, Cummins,
3. 54 gears, Deep Garnet Red, Agate, 4w ABS, tinted windows,
Camper and Trailer tow packages with trailer towing mirrors,
HD transfer case, snow plow prep, cab lights, travel conv group,
Mopar nurf bars, Downey SST cover, Bed liner with fifth wheel hitch
Power driver seat with power lumbar, loaded loaded loaded!!!!!!!
285’S BFG’S A/T TA’S KO, Amsoil Thur out
NO !!
I think you are describing the front band adjustment nut. Do not turn it or you will upset the adjustment.
Best location for a trans temp sender is in the cooler outlet line. Dodge sells a factory line from the older trucks or JRE sells a manifold kit. Either way you have to tap in the line somewhere. Do a search on here and you'll turn up lots of info.
Other option is in the pan,by either using an aftermarket pan with a fitting already installed,or modifying yours to accept a fitting. It's quite easy to tack weld in a fitting to the stock pan. If you do so,do the same with another nut and make a drain plug while your in there.
