Fix for poor headlights
plug boost elbow?
need some stereo advice
Originally posted by BSkinner
Yes, a Sylvania Xtravision 9007XV (in the pink package) or the Philips
equivalent I carry will perform better than the long-life / low output
factory bulb.
Where can one buy the Sylvania Xtravision 9007XV bulbs? Has anyone tried them?
Thanks.
Re: A bit of clearity............
Originally posted by ISBPilot
I have been thinking of a similar system... ... ... ... I know your thinkin' sure you were, but anyway. Here is my question. Why hook the relays to the alternator instead of the battery, or does it matter. I have relays for other things hooked direct to battery with relay turn-ons from switched sources.
Todd
According to the Daniel Stern web site it doesn't make any difference. I'd hook up to one of the batteries.
I'm waiting for a response from D. S. concerning the "plug and play"aspect of his kit. I don't want anything too complicated in the wiring department. If the kit comes with all of the connectors, I'll probably give it a try.
Bob
I plan to add driving light to my rig. Here is my idea. Open the hood and look at where the front radiator attaches at the bottom near the bumper. There is an extra hole in that bracket on both sides. I plan to make an "L" bracket that attaches there and will extend out under the bottom of the hood when it is closed. The lights will bolt to that bracket. Does anyone know how to wire the lights to come on with the high beams? If possible I don't want to break into a wiring harness. :D
Just checking.........
Bob
Thanks for the answer. I skimmed over the DS website. Lots of good info just didn't have time to read it all.
Todd
Has anyone tried the "Bright-box" kit for the 3rd gen from Geno's yet? I was wondering if it was causing the computer to through a code. I drive quite a bit now holding the turn leaver back to get more light on the road and would gladly buy the Bright-Box if it works as advertised.
Originally posted by ttreibel
Has anyone tried the "Bright-box" kit for the 3rd gen from Geno's yet? I was wondering if it was causing the computer to through a code. I drive quite a bit now holding the turn lever back to get more light on the road and would gladly buy the Bright-Box if it works as advertised.
Did you see the comment in the first post? I'm certainly not an electrical engineer but I buy the statement. I think that if high and low beam were in separate bulbs that it would work although maybe overheat the plastic headlamp assembly.
On another post somewhere around here (I think it was on TDR) someone pointed out that the wiring wasn't up to handling the load when the stalk was pulled back activating both high and low beams.
One thing for sure, these lights could use some help.
Bob
I posted this somewhere, I just tapped into the high beam wire with a scotch-loc. Used that as a signal trip for a relay. Do not disturb any factory grounds, use something else and you should be fine.
Projector Headlight Replacements
The problem being the reflector design, the good news is that APC is making full replacement assemblies that use a projector headlight for low beam, and traditional reflector for high beam. (I don't know how good the high beam might be).
The bad news is they're not making them for Dodges :( (I just got a new Stylin' Concepts catalog, and it lists them for Ford & Chevy :rolleyes: ).
Here is the Stylin Concepts web page for them; here is the APC web page for them. I just e-mailed APC at this address to ask them about the potential of a replacement for the '03 Ram, and referring them to the TDR discussions of the problem. Here's to crossed fingers ;)
I e-mailed Daniel Stern on Sunday and have received two immediate replies which was impressive. I had asked him about the "Bright Box". Here are his comments to my questions (printed with his permission):
VERY dangerous to use this kind of thing on a system that has high and low
beam in the one bulb. You throw a double overload on the ground pin and
wire, pressure inside the bulb skyrockets and the bulb will frequently
grenade inside the headlamp (literally!) destroying it.
Bob
I would be curious to hear from 'Bright Box' owners if they have experienced any problems. Up 'til now, I have been seriously considering this product. I still may add to my x-mas list only because I've never heard of anyone having trouble.
Re: Projector Headlight Replacements
I had projector beam headlights APC's on a Ford SD . They looked great. I wish I could say that they performed well. They didn't ,not for $300+
Re: Re: Projector Headlight Replacements
Rats! :( Although, noticing their label on some of the questionable-looking aftermarket products (including auxilliary lights) in the auto parts stores, I guess I'm not surprised.
I just got a response from "Ron Alcazar" -- email address removed -- quoted here verbatim in its entirety:
we were going to but that might changed in thr long run just keep checking with us
thank you
