Flat Rate to replace Cam Plug
Transfercase rattle
R&D continues...
The trans is not that heavy get under there and pull it. I'd say that it can be done in 4 hrs if every thing went good but how likly is that.
Hey, I've gotten lucky before;) :-laf I can do valve adjustments pretty well now.
bonzai-
I used a floorjack and ratchet strap for a transmission jack. I aint strong enough to lift the Getrag up into where it's supposed to go while lying on my back. Need to hit the gym, I guess. While you're in there, I'd replace the rear main, unless it was COMPLETELY dry all around it. If you were closer, I'd do it for you for less than a shop, and I promise to have it back to you within a month... .
Daniel
