Jrissler said:If you llok close you will see the front tire is off the ground, I'm in the process of making a lift axel on it, so far so good.
I've never seen a triple axle with that much spread between the axles. :--) Are you making it air lift, so you can pick it up going around corners and such? I can't imagine tires wear all that well on that trailer.
Michael
