RustyJC said:I agree - for mall cruising or even towing in moderate conditions, electric fans might be OK. For running at (or above) maximum GCWR with a tall trailer in Texas summertime conditions, however, they won't cut it. Caveat emptor.
Rusty
The Model 350 I used was purchased in 1999 - I'm sure it's been superseded, but it was the largest electric fan setup Flex-a-Lite had for the Dodges at that time. If left idling with the lights and A/C on, the 50A draw would pull that battery down in short order, so 600W was effectively about all the truck could handle.DBazley said:One thought: I went to www.Flex-a-lite.com and looked up the fan you used - actually they didn't list a 350 but a 340 - the same unit ?
RustyJC said:The Model 350 I used was purchased in 1999 - I'm sure it's been superseded, but it was the largest electric fan setup Flex-a-Lite had for the Dodges at that time. If left idling with the lights and A/C on, the 50A draw would pull that battery down in short order, so 600W was effectively about all the truck could handle.
Rusty
The V-10 used the same radiator as the CTD. Heat rejection rates certainly differ, but my experience is still valid for reference.nps said:One other difference - Rusty's experience was with a V-10, not a CTD. Don't know the coolant and air flow rates through the radiators in front of the 2 motors, but the airflow requirements between a diesel and gas motor may be different. Don't know - just pointing out the difference.
From what I have read is that at road speed, 55 + you're being cooled by ram air - the force of oncoming air, not your engine fan at all. Yet it's turning all the time, consuming energy that should be driving your wheels forward.
I read a story (can't remember where) that concluded running with an open bed and the tailgate up gives the best MPG, even compared to running with a cover, topper, or the tailgate down. Something to do with the turbulence breaking the vacuum at the rear of the vehicle.Cooker said:Neither the tonneau or the electric fan added any measurable incease in MPG's.
Mine has kicked in ever since it was new pulling a load up a 6% grade, even when ambient temps are in the 60-70's. Agree it never kicks in when towing on flat land, even when the ambient temp is 95+.JJW_ND said:II never heard my factory Clutch fan kick in, nor did I see the coolant temps rise above 190 in 200K miles of heavy towing (4 gear on the govn for 100s miles). All towing in open country... no stop and go.
MCrossley said:for using for on road use I am not trying to start an argument but how do you figure the electrics would be of savings in the long run HP is HP and whether you use electric or engine driven it sitll takes HP. '
In fact I would be willing to say that it is less efficient to run electrics you are going from mechanical energy to electric engery and then back to mechanical instead of just mechanical direct?
I may be wrong just want to bring that thought up. Also alternators are not 100% efficient and so you are probably putting a considerable amount of additional stress on it and the batteries as if you have the A/C Headlights Radio and your trailer lights then you add 50A to that you are well past what the alternator can put out for long durations and shortening its life by subjecting the windings to substancial overheating. Anyone else thinking along these lines?
