I installed my Fluidampr finally today and wow what an ordeal this has been for me.
First off I wanted a 6K tach and a fliudampr, so the tach I picked from autometer required 4 signals from the damper and the damper only has 2 grooves in it. so I went to a local machine shop and asked if it was possible to add 2 more grooves in the damper so the tach would work. he sad no prob. but then I wasn’t to sure about the factory pick up and how it reads only 2 signals from the damper so I wanted to do some research before he milled the $320 part.
I told him hold off for now and ill let you know
So I started my research and the very next day he called me and said the part was done. :{ So now im stuck with it, now what do I do??
Well here is what I did.
I filled in half of each groove that was made, the inside towards the engine was filled and the other was left alone.
so now I have 2 grooves for the factory tach and 4 for the autometer tach
I took some picture of the process and also of the fabbed pick-up bracket for the autometer tach. Ill post pictures when i can
Michael
Michael
