GRotman said:So Flux is more like a brand name then a modification process?
How do you change the angle of the spray pattern without making the hole size so big they would not be streetable.
GRotman said:How do you change the angle of the spray pattern without making the hole size so big they would not be streetable.
RMalone said:So, anybody hear when the Flux injectors will be available for 04. 5 and up engines.
OT-OF-HERE!! said:DD is carrying EDMs that are also new injector tips and have 8 holes. Very nice performers.
Tomeygun said:soon grasshopper, Very soon I hear![]()
Diesel Power said:i would be interested to know if any of you have seen a desent increase in power, going from extruded honed to edm---this is something that i have never seen, acually just the opposite, just curious,thanks![]()
lmills said:12 valves like extruded injectors. 24 valves do better with edm's The common rails are still up in the air. The fuel to supply serious hp was not available till recent months. Only time will tell.
Tomeygun said:Even for 3rd gens?
If so thats awesome!
Diesel Power said:not start a war, but i have put some extruded honed injectors in with a certain combo and seen pretty impressive results about(90)hp increase thats with just the addition of injectors and tuning, the same truck with other edms, did not make more than 30hp or so with tuning. so im not to impressed, but time will tell. the truth is that there are certain combos will make more power with certain injectors, i just wanted to see if any one saw the results like i have. thanks
Diesel Power said:are you going to dyno any time soon?
