i have an 01 sport and just the other day i noticed that both of my fog lights were out. the backlight on the switch to turn on/off the headlights/fogs has been out for about a year and like some of the other threads say it was in and out for a while and you could usually hit the dash and it would turn back on. but the fog light symbol will still illuminate when the lights are on but nothing else on the small panel will. i put silver stars in all my headlights and fogs and every two weeks or so my right fog would burn out. after replacing the $20 dollar buld twice i pulled the wires out and ran new wire into the bulb. that was months ago and has been fine since. . until i discovered both lights were out. however the bulbs are not fried. so i gotta think theres a deeper wiring issue. any ideas on where i should look first. . i would think that the backlight illumination on the switch and the fogs not working are not linked together bc it hasnt been an issue for the last year.
i havent had the time yet but im gona pull the dash apart and look at the wires running into the switch and see if theres anything visible like a wired pulled out but other than that im not sure where to start.
