Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canConvertThreadToRmsItem is not callable on the given object (SV\SearchImprovements\XF\Entity\ThreadCollab) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsReview is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsQuestion is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsFaq is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsEvent is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsLocation is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsCheckIn is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
Fog light switch bomb-ing?
autometer A pillar mount
Horton fan installation on 2001
I like to drive with the fog lights on. I was disappointed with my new truck's stock fog lights switch that could only be turned on when the headlights were on. The switch can only be pulled out to turn the fog lights on when the parking or headlights are on. I ordered a second headlight switch and disassembled the switch. I believe I can modify the switch so the fog lights can be turned on with the parking and headlights off. Anyone see any problems with this modification? I'm I bombing just a little?:cool:
You could do that setup, but the Ram has reverse wired headlights, the fog lights may have them too. Inother words, the ground is switched, not the positive.
Boy they sure are trying to make the new ones tamper proof. On the older trucks all you had to do is move a couple of wires to bypass the lights on only fogs. Cap, the only problem I can see with your mod is that it's illegal in some states to run fogs without the headlights on, don't ask me why, but you may want to check first.
Here are the California foglamp rules:
24403. Any motor vehicle may be equipped with not to exceed two
foglamps which may be used with, but shall not be used in
substitution of, headlamps. Foglamps shall be mounted on the front
at a height of not less than 12 inches nor more than 30 inches and so
aimed that when the vehicle is not loaded none of the high-intensity
portion of the light to the left of the center of the vehicle shall
at a distance of 25 feet ahead project higher than a level of four
inches below the level of the center of the lamp from which it comes.
24405. (a) Not more than four lamps of the following types showing
to the front of a vehicle may be lighted at any one time:
(1) Headlamps.
(2) Auxiliary driving or passing lamps.
(3) Fog lamps.
(4) Warning lamps.
(5) Spot lamps.
(6) Gaseous discharge lamps specified in Section 25258.
(b) For the purpose of this section each pair of a dual headlamp
system shall be considered as one lamp.
(c) Subdivision (a) does not apply to any authorized emergency
vehicle.
