Is there a simple way to have the brights and fog lights on together?
You can also do what I did, in the PDC pull the fog relay put a jumper wire from pin 3 to pin 5. This worked on my 01.
I went back to Issue 69 and found that you jump from 30 to 87. Then check to make sure the fogs turn off when switch is off.You can also do what I did, in the PDC pull the fog relay put a jumper wire from pin 3 to pin 5. This worked on my 01.
I turned mine on with my bullydog programmer, fog lights stay on with my brights, also turned on my daylight running lights with the tunerIs there a simple way to have the brights and fog lights on together?
Thanks for the replies.
I have two fog lamp relays, fog lamp one and fog lamp two.
now what?
So you are saying to completely remove the relay?
Sorry I didn't know that a 98 had 2 relays. If you remove one at a time does the fogs go together or just one of them? If they both go out when one pulled jumper wire that one, if one at a time goes out you could try to jumper wire both relays. Let us know what happens.
