grabinov
I addition to the problems associated with turning a corner with a locked alle (or set of locked axles), almost all four-wheel-drive vehicles are slightly overdriven in the front drivetrain (a lower numerical gear) - in other words the front wheels are designed to turn ever so slightly faster than the rear ones. This is done in order to help keep the vehicle from wanting to "swap ends" as could happen if the front ever turned slower than the rears.
This is no problem on low traction surfaces or even marginal ones like wet roads, but try it on dry asphalt and you are bound to cause somethin to bind up...
