ppeters,
Turn down the heads of the studs as in the head that keeps it from pulling thru the hub? I am confused. Doesn't the rotor go on the outside of the hub and the knurled portion of the stud fit thru the hub and rotor to hold it? I must not be envisioning this correctly then. If its the head thats not a big deal. If it is the shoulder on the stud thats a different story. If you can clear up the confusion it would help before I send them the money for something that doesn't work right.
As for the EGR setup, its a great high quality product. However the difference between $2000 and $600 is more than a little bit.
Am I pricing the wrong kits?
Thanks for any insight you can give.
