Your truck will run and drive just fine without the front driveshaft, except in the mud of course. Curious why do you want to take it off??
fuel savings, wear and tear on front drive line (joints and transfer box). I understand when a joint lets go it can cause extensive and expensive damage.
If you're going to remove it you will need a high quality long reach T40 torx bit and a breaker bar, and an 16mm box end for the T/C end. Be advised these fasteners are installed with copious amounts of loc-tite so impact guns will likely just break your torx bit.
I just spent $400.00 and change for a new front drive line. The problem is that neither are serviceable or greaseable by the owner, or anyone else. I find that vexes me somewhat.
There is a portion of it that is greaseable via needle grease fitting...
I was aware of the wheel bearing greasability but I saw no point on the driveline that offered that option. I'll have another look at my old one.
You won't save much just by removing the DS, as the ring and pinion are still turning. If you want savings, install a free-spin kit.I don't the savings for fuel economy & power gain, are worth taking it off. And it will be no fun having to lay in mud to reattach it when you are stuck... just my thoughts.
Do all years of the 3rd Gen truck have the greaseable joint? My (ever fading) memory seems to recall that it started sometime after '03.
Steve
Steve
