Hi All,
Well, fixed the death wobble with new tires (Michelin LTX. MS) followed up with both upper and lower ball joint replacements on the passenger and drivers side. The ball joint job was $600, including alignment. My problem: a few days later the front end started losing gear lube from both sides of the front axle. The drivers side has developed a pretty nasty leak, and the result being a pull to the left when braking. So, I intend to get this truck back to the front end shop. I assume they neglected to grease up the seals before re-installing them.
Can anyone give me any more ammunition to confront these guys? I will refuse to pay for any labor to fix this. In my opinion, if the seals were bad to start with they should have told me before putting the whole potato back together.
Thanks all in advance.
~Chris
~Chris
