Been noticing a gradual increase in a 'thunking sound' from the front end while turning the wheel or driving over a rough road. For the record, this frame has almost 400,000 miles on it. Drag link, tie rod, etc. are all relatively new (< 10,000 miles). Jacking up the front axle and checking freedom of movement shows that the ball joints are also still tight and they have been religiously greased. Front springs and bushings are also relatively new with polyurethane bushings. Since this is a 4WD the front axle u-joints have been changed to greased units and are relatively new. Steering box is 3 years old and still tight.
Is there a history of some of the rivets fatiguing / working loose and if so which ones? May need to do a ball joint replace anyways but would like to catch the rivets if they are bad / suspect.
Thanks for your help and comments!
