I read on another thread that the front end trailing arm eccentrics if not adjusted the same could make our trucks drift or pull to the left or right and to avoid this, is to have the eccentrics the same. Now is that accomplished by aligning the hash marks up to be the same on both sides because if so I think my truck may be pulling to the left because my adjuster on the drivers side is at about 5 1/2 marks going clockwise from lower left and the passenger side is at about 2 1/2 going counter clockwise from the lower right. Can I turn these say the drivers side to match the passenger side or will that effect my alingment as it has been checked and was "within specs. " and if so how do I go about it, just loosing and turn or should the front end be off of the ground.
Hope this makes sense to you all and thanks for the help.
Paul
'96 2500 ext. cab, LB, 4x4, 5 speed, 3. 54, TST 280 cam plate, AFC spring kit ,pyro and boost gauges mounted on A-Pillar, tinted windows, 16x8 Eagle alloys series 1219, 285/75R16 Durango A/T's, stainless steel rocker panels and alluminum stirrup steps
Paul
