Front Hub bearing HELP!!!!!!!!!
DD2 - Increased my Smiles-Per-Mile
How small is the DOWL PIN PROBLEM?
Hello All,
I thought I'd do my front and rear brakes today after work. I got the carbomet pads and also picked up new rotors to do the job right. I removed the center nut and the 4 bolts from the rear of the bearing that bolt it into the knuckle assembly. Rotor wiggled slightly but wouldn't come off. I grabbed a 4 leg puller as per the service manual and lo and behold it popped off or so I thought. The bearing pulled apart with the rear casting still stuck in the knuckle. Now I need a new bearing assembly and no matter what I do, I can't get the remaining rear half to pop out of the knuckle. I am truly baffled and stuck. Anyone please give me some ideas. Have any of you encountered this before?? Also have any ideas where to find a bearing assembly?? Right now I don't dare try to do the other side until I can resolve the drivers side dilema first. Sorry for the long post.
Thanks
Ron
1998. 5 2500 quad cab long bed 4. 10 LSD automatic, 285/75-16 coopers, add on cab clearance lights, tailgate running lamps, Navigator backup lamps, MSC fog lamps, Banks PYRO,trans temp,boost guages on Apillar, Autometer fuelpressure guage on floor, DTT Convertor and VB, Magtec transmission pan, Psychotty Air, BD 4" turbo to tail exhaust, Edge EZ box, RS9000 shocks
Hello All,
Disassembled the other side and same thing happened. Bearing came apart. Decided to get the BFH and large chisels and wedges and beat on the chisels to wedge apart the rear of the bearing from the knuckle. Definately major rust and corrosion holding these things together. Will wire wheel the ID of the knuckle and use antiseize on the new bearings providing I can find some. If not, I guess I will have to go to the dealer on Monday and "take my reaming like a man" for 2 bearing assemblies. OUCH!!!!!!!!
Thanks
Ron
I did my ball joint Thursday after work and had the Right side come apart. I used a press to put it back together. The outer seal was the only hard part of the operation. In hind sight coming apart is a good thing it allows the bearing to be repacked with grease. I a couple of weeks I have benn thinking about taking the other on apart to pack it also.
EAT'M UP
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, & Psychotty Air System, TST #11, 370 HP injectors, timing at 16 deg. , 16CM2 housing, AFC spring kit, TST EGT gauge & 0-60 boost gauge in A Pillar, Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, 2 Electric Fans, One inside/ One out front, AmsOil Through out, Geno's trans filter kit, AmsOil Bypass system, Lund Winter front, Leer Cab Level Shell Driftwood , 255/85R16, South Bend's Hypo Clutch*NRA/USPSA member and proud of it*
Ron---In our shop we use some dummy bolts that are 1 1/2 inch longer than the stock bearing hub bolts. They stick out far enough to pound on the end without causing any problems... Sam
