I've read all the search results on front hub removal so I can replace a bad U joint. I purchased a 1" 11/16 socket and a big can of PB Blaster penetrating oil. Big axle nut came off easy as did the 4 12 point bolts holding on the hub. Of course the hub is frozen on. I hate to use a puller since I don't want to separate the bearing (besides I don't have a puller that big). I've been using a socket and extension and beating on the loosened rear bolts but so far no results. Has anyone come up with any new tricks that worked well? I also bolted the wheel back on and kicked it as one poster mentioned. No luck there either. I plan on more penetrating oil and more patient beating but that gets old fast...
