2nd Gen Non-Engine/Transmission front sway bar links
Engine/Transmission (1994 - 1998) tranmission leak ?
Engine/Transmission (1998.5 - 2002) 4wd to 2wd
Has anyone replaced their sway bar links? My Haynes manual says I'll need a "two jawed puller". Don't happen to have one just lying around the house so my question is do I really need one.
Many jobs that call for special tools can be done with out the use of those tools but with some risk of colateral damage. Tie rod ends should be removed using a special tool but the reality is more are done with-out any special tools.
A bfh will get the job done since there are no aluminum parts in your case
No just leave nut on a few threads and hammer. They pop out pretty easy. Also i believe 94 have slightly different swat bar links. Actually sure of it. Make sure you check build date to get correct ones.
