Fuel additives
West coast mechanic J leonard # wrong
Sticking brake calipers
I am new at this diesel game and would like know if I should be using any type of fuel additive to keep the injectors clean.
99 2500 Laramie SLT 4X4 QC auto 3. 55 LB stock (for now)
Some people say you don't need to if you buy clean fuel. Some do it for insurance and to keep out moisture. Personally I dump in a bottle every fuel up. I carry 100 gallons when full and I feel like it helps keep down condensation. A bottle of the PS. stuff treats 100 gallons, works out just fine.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, lock-right locker, 3. 54 gears,ez edge, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
A local diesel/turbo shop recommends some additive (I use the Stanadyne in the blue bottle) at every fill up. They say moisture will kill the pump faster than anything. If you use a good additive that will be prevented. It's not only good insurance, it makes the pump operate a lot quieter, too.
2001 HO 6 spd 2500, 4. 10 LSD, Towing Package, Electric Brakes, SPA EGT/Boost Gauges, Fog Lights, Real Backup Lights, Molded Running Boards
Steven... . I have used Redline 85+ in the tank before I pulled off the lot.
I have also tried LE DCI+. I was hoping for some mileage improvement, but have seen none over 6K miles from either brand.
Both of these brands have quieted the engine, and I hope, provided the lubricity for my injection pump which is the main reason I decided to use it.
Have a friend who swears by Howes, so that's my next try.
Do a search on fuel additives. There's a lot of info.
White 2001. 5 2500 ST, SWB, 4X4,QC, AUTO, 4. 10's, LSD, 285/75/16 On Weld Outbacks, PIAA 510's, Line-x, Tinted glass, Redline 85+, Blow-by-bye, RE-0880 & 25-0880,muffler fell off,level truck with 2" tuff country kit, Bilsteins at the corners, Di Pricol egt and boost, Mag-hytec "original flavor" transmission pan and Dana 70 diff. cover, Westin Step Bars, Custom Plate 24V-DSL
Steven,
There are lots of additves to choose from as you will see with this post.
I have been using HOWES based on my brother-in-laws recommendation whom has driven 18-wheelers for 20 years. He tells the story, “how a few years back when the temperatures dipped below freezing in the upper mid-west and all the other truckers fuel was freezing up, how he just kept on going, driving by truck after truck on the roadside and at truck stops because he used this product. ”
I use HOWES Lubricator in the winter and HOWES Leaner Meaner in the Spring/Summer.
Hope this helps. ------------------
<font color=forestgreen>2000</font> DODGE <font color=forestgreen>RAM</font>, <font color=forestgreen>2500 HD</font>, 4x4 SLT, Reg. Cab, <font color=forestgreen>Forest Green</font>, Agate interior, Cummins ISB, Auto, Shift-on-the-Fly (241HD), 4. 10 LS, ABS, Trailer Tow Group, Camper Group, Michelin; DC: Fog Lights Kit, Tow Rings, Under Rail Bedliner, VentVisors, Splash Guards, Cold Weather Cover, & Mats.
<font color=forestgreen>After-market</font>: High Idler, Heavy Duty Idler Pulley, Gatorback Belt, Painless Wiring, K40, Viper w/AutoStart, Clarion 6 Disk CD w/remote, UnidenCB w/Francis antenna, Draw-Tite Activator II, Alpex 255TC2C Air Horns, Continental BedRails, Delo 400, HOWES, Liquid Glass.
BigDaddy's Ram #ad
New England RamRiggers
