Fuel Econmy Upgrades
stacking w/ injectors?
TS shift Master
propane injection helps with completly burning all the fuel. I have never tried to figure out but, what does it cost per gallon of fuel to run it in your truck, does it make since for the make up in mpg?
What about using at high pressures? The lift in the tires could decrease the rolling resistance significantly and the truck may only feel like 4000 lbs instead of 8000!
I was working an all nighter last night and forgot to add that "Helium" at high pressures! It could lift the truck right off the ground!
Thats not too bad. . with todays fuel prices that makes you get about 16mpg cost wise. At $20 propane for 400 miles and 19. 5 mpgs.
That's about right - and the only con is that if I want to smoke out some ****-ant Honda tuner fag, I have to really lug the engine. Sometimes I really miss my soot cloud...
not bying 30mpg, I drive 62-65mph. no freeway, live at 7000ft. 600mil. a month back- forth to work;banks autominde,ats intake,ats exhaust manf.
aero turbine muffler, ddp economy injectors,s&b intake & filter,tag3, free spin hubs, and all syn. oils. bed cover. 23mpg. verry best. 06 big horn auto trans.
Stock truck,turn off A/C, keep r. p. m. @ 1600-1900. No unnecessary trips, slow take-offs and coast up to red lights to avoid stop-and-go. No extra expense to do these fuel savers. I'm a 5. 9 G56 driver so these might not apply to others. I average 16 gals. /wk driving 72 miles/day.
