Fuel fill
Observations: HX-40 & Moderate Fueling
California vs Federal (49 State) Emissions
What can be done to reduce the foaming that shuts off the nozzle while fueling, leaving two or more gallons to completely fill the tank on my '99 3500? Trying for maximum range from the 35 gallon tank, that extra fuel comes in handy but it takes nearly as long to dribble in the last two/three gallons as it does to put in the first thirty.
Utah Willie
Reduce the rate of flow! Yes take twice as long on the first thity gallons and the last five should be pretty quick. So bring your favorite mystery novel with you the next time you fill up.
Bill Thomas
Missouri Mule - 96 Wht 4X4 ST CC,5 spd, 3. 54, 8 ft bed, 1 ft high cheater boards.
99 Freightliner bl/wht FL60 ISB-5. 9 24v,215 hp,520 tq,6 spd, 3. 59 nsr,16 ft box, 19. 5 tires,Wt/gvw 11,000/23000
I saw a guy once pull the left side of his truck up on 6" blocks in order to get more fuel in his tank #ad
. Seems a bit extreme up it works. He had the system down pretty good too, only took him a few seconds to do it.
2001 Driftwood 3500 Quad Cab 4x4, Long Bed, 5. 9L HO Cummins Diesel (ETH), 6-Speed HD Manual (DEE) Loven the shift thing (Arrrrrh), 3:54, SLT+, 3. 54 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, 18,000 LB 5th Wheel Hitch, Leather, Sliding Rear Window, BDs E-Brake, Rhino Liner (gray), Velvet ride shackles, cup smoothy, Power Edge box / EZ Box w/elbo, DD Stage III injectors, McLeod Dual Disk Clutch, K&N, SPA Gauges, Jardine Exhaust, 16cm turbo housing. Love the smell of diesel in the morning. Hope your watchen DC cuz every thing you see here is a big lie, Hehe.
Stay away from the big nozzles. While they are quick, they create a lot of foam.
98. 5' Emerald Green 24v 2500 Auto/3. 54 4x4 SB QC 285. 75. 16's Bridgestone Dueler A/T's on 16" x 8" Alcoa's under Rancho 9000's. Everything but leather. PIAA 1200's, AMSOIL dual filter relocation system, Smittybuilt Stainless Steel Nerfs, Rhino Liner(Junk).
Tilt the nozzle @ a right angle to the neck and slowly squeeze the lever so the fuel flows clear. A bit slow for the last few gallons, but you will be full. As a former PSD owner w/ dual tanks, this was the only way to completely fill the rear tank. The block trick helped also.
Steve in Spokane,01 4x4 Auto Quad Cab SB, NRA Life Member, 99- H-D FLHRCI Coalbalt Blue,00 XR650R Power Upped, Former PSD owner
I'm fixin' up a block and getting a small library set up in the truck but my wife has suggested that I just schedule local fueling for when Rush is on and then I won't care how long it takes as long as I can listen to him.
Could also try different stations. I did a post about this back in April. BrandA I could only get 25-27 gal in a fillup. When to BrandB. Consistently puts in 28-30gal per fillup.
Other than the first transition tank. MPG calculations are coming out the same. No change in mileage. However I can now go 50-60 mi per tank farther. Which lead me to believe in the foaming problem, and the flow rates at the two stations.
I always carry an ample supply of RUSH cd's in my truck. I never care how long it takes.
[This message has been edited by SlyBones (edited 05-11-2001). ]
Im assuming you guys are not talking about rush as in geddy lee????..... lol
uncle joe
01 swb 4wd qc slt+ intense blue with everything the only thing it hauls is my wifes big a$$
Is there any other kinda RUSH. Ever see the bumper sticker "RUSH is a band". I dont have stickers on my truck, but I am a total fan on Geddy, Alex and Neil.
Im sure the rush in quastion in the linmbaugh kind,at least what they were talking about,not that there's anything wrong with that!... ... uncle joe
When I bought my first diesel from Dave Smith in 1992, the dealership told me to run fuel in the tank at the slowest setting on the pump nozzle, so as to make as little foam as possible. When the automatic clicks off, quit.
Thats the way I have always done it. And with my '98 if I try to put more in, it pukes violently for 2 or 3 feet out from the truck.
98. 5 24 valve auto, QC, LB, EZ, DTT vb 9 1/2ft 3500# slide in S&S Camper
I carry alot of music and if the only thing on the radio during fillups was the bigmouth I wouldn't need FM at all. Count me in on the Rush fan list. And as far as the blocks on the phord, I had one at work I got new in 92 and had it till last year. I WILL NEVER AGAIN PUT A BLOCK UNDER A WHEEL TO PUT FUEL IN A VEHICLE. I DID IT FOR A 100K MILES AND FORD DID THEIR JOB AT KEEPING ME FROM BUYING ONE OF MY OWN. I'm not kidding, it took me 15 min. to fill both tanks. It's not bad when its 60 deg or up but when it's 20 and the wind is blowing you have to wonder who would have designed such a poor system and got paid to do it.
'99 QC SB White/Agate Auto 3. 54's Mustang Bed Cover, Bed Liner,BD PNP, 4" ex, 275 injectors, ISSPRO PYRO/BOOST A-Pillar,LOUD JVC CD, boost module and elbow coming soon. transmission upgrades needed soon
