I am in the middle of changing my fuel filter and have a problem. This is the first time I have done this so bear with me. I got the old filter off and swapped over the drain and water sensor, no big deal. I filled the new one with diesel and let it soak for about 15 minutes. I then dumped a little off to eliminate spillage, it was about 3/4 full when I put it on. I then opened the fuel bleed bolt and started pumping the fuel pump primer lever and nothing is happening. There is hardly any resistance on the lever, so far I have pumped it about 100 times and still no fuel is coming out the bleed hole. The truck ran great before I did this, so I assume the fuel pump is working as advertised. Anybody had this happen to them? Am I doing something wrong or do I need a new fuel pump? Any advise would be appreciated.
Pat Daniels
1991 4x4
Pat Daniels
1991 4x4
