I'm about to install my FASS fuel system and it comes with some large brass fittings. Does one need to put any sort of "pipe dope" for diesel fuel fittings, or do you just tighten them "naked"?
Originally posted by kboettcher
I use a pipe dope on all my fittings. I use the same one we use in the oil furnace installations. The product is called "Jet Lube No. 60". It's a lead base, so if you get some, remember to never use it on domestic water lines, or house plumbing. Whatever you do, DO NOT use teflon tape. I am sure there are lots of other dopes out theirthat will work, just stay back one or two threads with the dope, so you don't send some into the injectors. Thats the good thing about Jet Lube 60, because it is oil and lead base, it does'nt harden. So if some gets in the fuel lines it will wash right through.
