Fuel Gauge and Boost Gauge Installation Question
I just installed a dipricol mechanical fuel gauge that attaches to the bottom of the fuel filter housing, in fear of getting sealant to my cp3 I didn't use Permatex on the fitting that screws into the replacement banjo bolt, I had to use Permatex Red on the fitting between the hose and isolator because of a leak, it fixed the leak and now everything is fine, two questions:
1. Is the red permatex RTV gasket sealant OK for that fitting?
2. Am I more likely to develop a leak on the fitting where I didn't use any RTV sealant? Thanks, Jay
Also, where can I get the best boost bolt? I have read horror stories about them breaking off even when correctly torqued, I got one with my boost gauge from geno's but it isn't brass, should I get a brass one?
