Dan_69GTX
The connection for the fuel heater is now toast! So for now I just disconnected it. Everything else is fine - I checked the thermostat and the heater and the power to them.
It seems there was a bad contact at the plug for the power (located by the fuel heater).
In looking at the manual and checking the resistance of the fuel heater itself - what can be done to minimize the resistance of the electrical connection? If the resistance of the heater is 1 ohm and the resistance of the connection is 1 ohm, then you are having 150 watts oh heat buildup at the electrical connection and 150 in the heater. Soldering the connection would be best - but that doesn't help when you have to remove the fuel heater.
Any suggestions - or what have you done before?
Thanks!
Dan
Thanks!
Dan
